All The Way
Yaesu FT-8800R ham radio install (Updated)
The install went pretty smooth. I still have to buy, mount, and run the antenna. I will add that part to the thread later.
I also got the separation kit for the radio which made installation a lot easier.
I ran power directly from the battery. I found a small rubber plug on the passenger side of the firewall that was perfect.
![IMAG0011_.jpg IMAG0011_.jpg](https://www.fordraptorforum.com/data/attachments/177/177897-d3194c9c0525ce49d9ec6e6ec154233f.jpg)
I cut the center out for the wires.
![IMAG0018_.jpg IMAG0018_.jpg](https://www.fordraptorforum.com/data/attachments/177/177898-2821b8c482d43ecb78b63b75d5211856.jpg)
Tucked the wires behind the trim
![IMAG0012_.jpg IMAG0012_.jpg](https://www.fordraptorforum.com/data/attachments/177/177899-8f3839017a81f1427b3b00d8455b791c.jpg)
![IMAG0013_.jpg IMAG0013_.jpg](https://www.fordraptorforum.com/data/attachments/177/177900-d3667f39b76ff86941bd26a34dfff3a3.jpg)
The main part of the radio I put under the passenger seat. I'll have to block off the floor vent for the winter.
![IMAG0027_.jpg IMAG0027_.jpg](https://www.fordraptorforum.com/data/attachments/177/177901-ba365f77b29df814c1ac6bb335eaf256.jpg)
For the front panel I wanted to mount it up as high as I could so I see it with a quick glance. Problem is I didn't want to drill any holes in the dash and I wanted it to look clean. I had some aluminum brackets from work laying around and found it fit perfect for what I had in mind. I only had to drill one small hole in the center speaker tray.
![IMAG0020_.jpg IMAG0020_.jpg](https://www.fordraptorforum.com/data/attachments/177/177902-f13c4a9165dc72494b566d067421e86a.jpg)
![IMAG0022_.jpg IMAG0022_.jpg](https://www.fordraptorforum.com/data/attachments/177/177903-9e472a6ffa094e51a9b810f181fc8ab1.jpg)
With it mounted and powered.
![IMAG0025_.jpg IMAG0025_.jpg](https://www.fordraptorforum.com/data/attachments/177/177904-b8f5ff9069e8132f8aaf2631246d284a.jpg)
