It's always been this way, and as far as I've seen, there's no way to work around it.
As a software developer, it offends me that Ford did something this half-assed. They have all that data readily available, and couldn't be bothered to display it.
In the owners manual it says screen 2 is intentionally left blank and screen 1 is just trans temp.
Would love to have a large speed display option, tach value, voltage, coolant temp, lateral/longitudinal force (G), etc.
Vehicle manufacturers just plain suck when it comes to electronic user interfaces, with the possible exception of Tesla.
I know air intake temp is reported for OBD II. I know that EGT is not (no sensors for it). As far as AFR, I think wide-band O2s are needed (not 100% sure on that). I know that fuel trim is a reported value, but I do not think that AFR is - it would have to be calculated. Based on that info, the only one that would even be remotely possible would he air intake tempHow to install a reading there
AFR
EGT
Air intake temp
You learn something new everyday... Good info.The newer mustangs show afr. Idk how accurate it is though
Even the GT500's have a variety of guages in the LCD screen.The newer mustangs show afr. Idk how accurate it is though
Sent from my SCH-I535 using Tapatalk now Free
I had an Ultra-Gauge in my old truck. I liked it it a lot.Anybody ever use a scangaugeII? They monitor all that stuff throught the obdII. but still, ford definitely dropped the ball on that one.
