Alternator Part Numbers and Output Ratings
BigJ
This is for the 2010 Raptor:
There seems to be two part numbers for the 5.4L; one for those Raptor's equipped with Nav (pn 10346 GL-987) and for those without (pn 10346 GL-954).
There is only one part number for the 6.2 Raptor (pn 10346 GL-989)
The 6.2 alternator is rated at 150amp output.
The 5.4 w/o Nav alternator is rated at ???amp output.
The 5.4 w/ Nav alternator is rated at ???amp output.
Yukon Joe
Trafford, PA
Does anyone have a reliable source for what the alternator out put is for the 2012 Raptor? I have heard from the dealer that is was over 200 amps, but that doesn't seem to jive with what I've found on the interwebs (Which there isn't much).
Thanks,
Yukon Joe
(Yes I know... very old thread, but this is one of google the search results!)
Labraptor
Illinois
Joe I don't have the info but if I remember correctly Icecobra is the person to ask. If not then sorry Ice.
Sent from my DROID4 using Tapatalk 2
KaiserM715
Kaiser Söze
You might try sending a PM to pirate air. He might be able to get you a part number, which should be a good place to start.
