Cheap Bed Ring MOD
HAP
NE NC
Installed these tie down rings. Got them from Mopar Parts Overstock, RING RING-RETAINER #05104500AA for $3.44 each.
I modified my FORD mat with 3 1/2" holes to clear the rings. To align the cut out you can use lipstick or something similar to transfer the bolt center to the mat. I used a hole punch that I had, but a hole saw would work just as well to make the large hole in the mat. One thing that I found is that the dealer only torqued my bed bolts to about 20 ft lbs after having the spray liner added during the purchase. I bet some of the random popping I used to hear was coming from the bed as the frame twisted. Torqued them to the prescribed 59 ft lbs and one more simple and useful MOD complete.
R,
HAP
Palerider
Subd and added to the mod list.
Sent from my SM-G925V using Tapatalk
Deleted member 12951
@HAP, How did you get the washer off the bolt to put the d-ring on the bolt? Did you file down the ridges because it looks like the d-ring is between the top of the built-in washer and head of the bolt?
