Third Brake Light VHF Antenna Mount
OffroadAlliance.com
Boston, MA
Mounting an antenna has always been a choice between a temporary magnetic base mount or the very scary process of drilling holes in the cab of your truck. The Third Brake Light Antenna Mount is simple to install and can be done with basic hand tools. Installation instructions included.
Fitment: 2017+ Raptor, 2015+ F150, 2017+ F250/F350
The Third Brake Light Antenna Mount features a lot of great benefits:
- Clever Design allows for an effective and simple way to attach an antenna at the back of the cab of your truck.
- High-mount Location is the optimal location for maximum antenna effectiveness.
- Weather-tight Seal gasket on the back-side of the mounting flange creates a weather-tight seal against the cab.
- 15-foot Co-axial Cable that is easy to run inside the cab above the head liner and then routed to various locations for your radio install.
- Industry Standard Connectors with an NMO-style antenna base that is connected to fifteen feet of co-axial cable terminated with a PL-259 male UHF connector that works with a wide-range of popular radios on the market.
  • QUICK & EASY INSTALLATION
  • NO HOLES TO DRILL IN THE TOP OF YOUR CAB
  • BETTER THAN A MAGNETIC MOUNT
  • SUPER STRONG, BAJA TESTED
  • PATENT-PENDING
  • ANTENNA NOT INCLUDED
Link ---->>>> FORDRAPTORLIGHTS
