Did I not take it deep enough for her
MurderedOutSVT
Brodozin
The ATL
So my moonroof leaks....imagine that. I did a search, many times @Nex
I have done the string trimmer line ream out 2 times now, still getting a wet carpet(giggity) and the handle drips, water in the door seam channel.
Is there some point where I know shes satisfied and I've gone deep enough? Or do I need to find an out of the way place where I can can blow it out with a hose (gigitty 2)
Without waiting for anorther hard rain, what to do?
Nex
RIP CoronaRaptor
Washington State
Take the a pillar apart and see if everything is still attached. Did you check the bottom (drain) holes, (giggity)? Compressed air is good. Run a garden hose on the glass and check for leaks (close the sunroof first). Might be the seal around the sunroof overwhelming the drains.
