Outlaw Offroad
- Joined
- Apr 7, 2011
- Posts
- 624
- Reaction score
- 311
Vertical Tire - Quick Release Bed Rack System.
This compact design, vertical dual spare tire rack has all of the necessary features any off road enthusiast will need. The rack is made of 1-3/4” and 1-1/2” DOM and is covered with durable Line X to prevent scratches and wear marks. The quick 4 pin system makes for easy removal in seconds. “ Just pull the pins and pull up” The rack is designed for the use of 35” or 37” tall tires and features “Roll in, Roll out” tire carriers. The tires sit vertically and fasten down by 2” ratchet straps. The inner mounting system of the rack allows for you to securely hold a 5 gallon gas can and an 8 gallon Action Packer tote for tool and gear storage. The gas can and tote are fastened down by a custom made 1” “Y” strap. Underneath the tote, a Craftsman 2 ton aluminum race jack is mounted on a quick release pull pin mount for easy access when needed.
The rack itself sits below the bed line, making it possible to have a removable bed cover installed even with the rack installed. The rack can also be used to secure motorcycles down.
Specs:
Holds Two vertical spare tires (35” or 37”) “Tires not included”
1-3/4" and 1- 1/2" DOM.
Line X
Included:
(1) 5 gallon gas tank,
(1) 8 gallon Action Packer Tote (that are held down by our custom made Y-strap),
(2) 2” Custom made spare tire ratchet straps.
(1) 1” Custom made “Y” ratchet strap.
(1) Fire Extinguisher with quick release mount,
(1) Craftsman jack quick release pull pin mount. “ Mount Only”
Web Link: ORP Vertical Tire Bed Rack | Outlaw Raptor
35" to 37" tall tires.
Specs:
Line X
Included:
