Aftermarket Wheels
BajaFred
I had these rims on my 6.2 Raptor. When I went to put them on the 2017 I found out that they changed the studs. The old raptor is14×2 and the new one is 14×1.5. So if you are going to use existing rims you will need to buy new lug nuts. Hope this helps someone!
What size tires?
ChevyChad
LT275/65/R20 Nitto Ridge Grappler
Why would you downsize the width and diameter of the tire? Factory tires are 315/70/17. You are giving up 40mm (1.57") of tire width and ~.3" of diameter..
Johngm45
I'm changing my 22's to a set of 17" OMF F1 forged with Sim U Locks . Wanting more tire than wheel db179c1de79b461df34f097cb8fd9f7f.jpg
