Securing spare tire with Y strap
Bigg50
Benicia, CA
I have the rear dovetailed so I needed a way to carry my spare tire in the bed. I do have a chase rack coming from LEX but I still needed something for daily use. During the winter we make trips up to Tahoe and I need to use my bakflip to protect our gear from the elements.
The Trailer bed bolt is removable and sits pretty flush with the bed. It comes with a separate cap that plugs the whole as well. The dodge d rings fold flat as well. So far it's worked great over about 400 offroad miles.
Parts:
Mopar 05104500AA RING-RETAINERS
ProGrip 822820 1/2" Removable Trailer Bed Bolt with 2" Shank - Pair : Amazon.com : Automotive
Race Ready > Speedstrap Spare Tire Ratchet Straps
Since my rack wasn't here yet in time for last weeks Carson run I threw both spares in the bed. I wouldn't recommend doing this on a regular basis as the bed middle bed bolt will take a beating from the increased levarage of the 2 spares.
BobCajun
Ashburn, VA
Curious why you went with the bed bolt and not a 3rd D-ring? Raptor arrives in a couple of weeks and trying to plan a similar solution ahead of time.
amphibian
Midwest, US
Got a link or part# for those D-rings on the bed bolts? Those look like exactly what I need.
Edit: Duh, nevermind I see it now. Just missed it because it didn't jump out and hit me in the face.
Bigg50
Bigg50
Benicia, CA
D ring would work. I already had the the bed bolt so I used it. You'd just have to get a washer, bolt, and nut.
I'd also like to mention that the washers on the existing truck bed bolts will have trouble clearing the collar of the bed bolts. The wholes are just a little to small. You just need to get a large socket and place it Over the bed bolt. Then hammer down on the washer. It will eventually clear the collar. Then place the d ring on the bolt and the washer at the bottom of the collar. Then begin ******** the bolt back into the bed. Eventually the pressure will get the washer over the collar and you're all good.
KKILLIAN
The Y straps work great. I have the same setup, but I made my own mounts.
Bigg50
Bigg50
Benicia, CA
I'm pretty sure I saw a pic of your setup at one point which gave me the idea. I'm very happy with it and I like the "look" as well.
SvtDon
San Diego Ca
I've been up and down about my set up too due to bed cage. Doing this keeps it low profile and clean looking. Not to mention light! Think I'll be doing this too since I'm going another route.
Sent from my SCH-I545 using Tapatalk
Bigg50
Bigg50
Benicia, CA
Right on. It should work well for you. The other option is the mount from tiregate but you have to drill 5 holes and one is pretty damn big.
I assume you're getting the 3.5's in the rear? I'm sure it's going to be a crazy setup.
SvtDon
San Diego Ca
Already have it buddy. No tire gate. Don't like that much. Think the strap will keep it all clean!
