tool box roll cover
firematt422
Kansas City
Truck Covers USA
I have the American Work Cover, works like a charm. It's a little nerve wracking drilling holes in your bed, but it's worth it.
I got mine from autoanything, they run a deal every so often for 10% off your purchase to a new customer... apparently there's no upper limit on the deal because I got mine 10% off.
And just for fun, Kicker Marine 6 1/2"s and a 10" Sub in their happy water-tight home.
Badrap
Mabank, Texas
Have the Roll n Lock. It works great until you decide to off road and jump with it. Mine is a on going adjustment PIA. It's still caved in from the TRR. I'll probably replace with a Bak flip.
BigBlock
American Roll Top is made of double-walled black powdercoated aluminum. It requires four drain tubes, so you have to drill two 1.25" holes at the rear just below the stake pocket floors. The cover comes with rubber grommets, so the holes look OK. The cover is very strong and spring loaded. Be sure to order the optional "keyless entry". The term is misleading, just know that you should get it. They also have two toolbox cover combos: American Work Cover and American Work Cover Jr. (smaller toolbox).
RollNLock is made of vinyl laminated aluminum. The vinyl has the potential to be a problem, someone could cut it. Also, the vinyl fades unless you keep a conditioner on it. The cover requires a rail to be installed on the inside of the tailgate, you have to drill four small holes in your tailgate.
Which is a better cover? Truck Covers USA.
Different truck, but...
enjkuck
I have the American roll cover on mine and love it. No problems with it and I off road in Montana (No Jumping, Just wheeling). Looks good too.
