![DSC02351.jpg](/proxy.php?image=http%3A%2F%2Fsdhqoffroad.com%2Fimages%2Fproducts%2Fdetail%2FDSC02351.jpg&hash=25c254cec618336d4a6415fbbb09a6d3)
SDHQ Ford Raptor Rear Frame Reinforcement Kit
Cost: $100
Time: 20-60 mins
Difficulty
1 2 3 4 5 6 7 8 9 10
SDHQ revised their frame reinforcement kit for 2013 Raptors due to the thicker frame walls. In fact, that tidbit of information led to the discovery of the manufacturing change. If ordering, SDHQ will ask the year of your truck for that reason. The fit and finish of the 2013 revised reinforcement kit is excellent.
The installation is straight forward. You will need:
3/4" socket
9/16" socket
Hook tool (optional)
1. Jacking the truck up and removing the tires is optional in my opinion. I did the install with the truck on the ground.
2. Insert the large gusset plate through the oval opening on the inboard side of the frame rail. SDHQ already has great pics so I didn't bother taking any more.
- On the driver's side you will need to unclip the brake lines from the plastic retainer to allow room for installation.
![DSC00854_zps2c9e174a.jpg DSC00854_zps2c9e174a.jpg](https://www.fordraptorforum.com/data/attachments/195/195009-e2175db33af2c594d5d4b7004341e193.jpg)
- Insert the large gusset plate in to the frame. There is an arrow cut in to the plate which should point toward the front of the truck. The "flat" side of the plate needs to be down. The nuts on the gusset plate will face inboard toward the oval opening.
![DSC02336.jpg DSC02336.jpg](https://www.fordraptorforum.com/data/attachments/195/195010-ba38c168756600066c851599fa815154.jpg)
![DSC02340.jpg DSC02340.jpg](https://www.fordraptorforum.com/data/attachments/195/195011-7ba458c417142cbf302283d6ada19f9c.jpg)
As has been said before, it can be a little tricky to get the large gusset plate inside the frame rail if you don't have it oriented properly. Rather than try and explain, I'll save you the frustration and made a quick video showing the way:
SDHQ frame kit - YouTube
- Once you get the large gusset plate inside the frame, just reach in and hold it up so you can insert the bolts from the outboard side of the frame through the slotted holes. Secure with 3/4" socket.
Torque to 90 lb-ft
![DSC00853_zpsd43b9763.jpg DSC00853_zpsd43b9763.jpg](https://www.fordraptorforum.com/data/attachments/195/195012-ca2ea8ea7d28ff6d9ce0211c9f1ed502.jpg)
3. Install the smaller gusset plate to reinforce the large oval opening.
- Insert the parallelogram shaped plate in to the oval opening with the nut side facing outboard.
![DSC00855_zpsd7500f08.jpg DSC00855_zpsd7500f08.jpg](https://www.fordraptorforum.com/data/attachments/195/195013-538be17b1c186157e8952d49cbd717ea.jpg)
- Use your finger *or* a hook tool to hold the inner piece in place while you help thread the bolt.
![DSC00857_zps475c8223.jpg DSC00857_zps475c8223.jpg](https://www.fordraptorforum.com/data/attachments/195/195014-e11830545fa4b9d3bdc4dec977c8f089.jpg)
![DSC00859_zpsc67376c3.jpg DSC00859_zpsc67376c3.jpg](https://www.fordraptorforum.com/data/attachments/195/195015-dda0978249fdb8001353de3963a27448.jpg)
- Insert the bolt through the oval shaped gusset plate, in to the inner plate and seat in to the opening like so:
Torque to 40 lb-ft with a 9/16" socket. You may need a 9/16" box wrench if clearance with the exhaust is an issue.
![DSC00860_zps829a0f94.jpg DSC00860_zps829a0f94.jpg](https://www.fordraptorforum.com/data/attachments/195/195016-b892b84dceec066821696780d9d838a9.jpg)
Done!
I think in conjunction with the "reinforced" 2013 frame, the SDHQ Frame Reinforcement kit and rear 3.0 ICON bypass shocks (coming soon!) I have a bullet proof solution for moderate to heavy offroad use. If I am able to bend my frame after all is said and done, I would hope my spine is still in alignment too!
This kit from SDHQ is a must have in my opinion if you're not doing a full bump stop kit. Even for the casual weekend warrior, $100 is a small price to pay for a little peace of mind. Adding a 3.0 shock can only further help your chances of trouble free Raptoring...again if you don't want a bump stop kit.
The kit its self is nicely powder coated, and comes with all necessary Grade 8 hardware. No drilling or bed removal necessary.
Thanks SDHQ
