3Rd brake light issues.
derrhunter
Hey is anyone having problems after you wash your truck the brake lights stay on. It seems that evey time I wash my truck or it rains out and get the 3RD brake light wet and then is starts but after it drys out the brake lights go out and start worhing right again. Please help. Took my truck to the daler and they told my because I have after market lights that the warranty would not cover it and they wouldn't even look at it.
SOCOMech
Famous Raptor
Phoenix AZ
Look for any spots that water may be getting in and getting into your wiring. Even the stock 3rd brake light assembly has had a few instances where water got in and caused the hill descent control fault light to come on. It could easily cause a short and allow your lights to work on and off or stay on.
Raptor2010
PA
I had the same problem were the rain would get in and short out the LED lights and cause the hill descent to malfunction and the traction control would malfunction also. also when that happens i also found out that you have no brake lights when hitting the brakes. the dealer replaced mine under warranty and just recently the new one they installed did it once. A lot of people are having this problem with these. i started a thread awhile back on this same issue. This is an issue they should address i think. I disconnected the LED plug and it went back to normal. When you take the 3rd brake light off you have 2 plugs going to the white lights and the LED's. The LED's are the problem not the white bulbs. you can leave them hooked up.until you can get it looked at if you wanted to do that.
Raptor Retrofit
HID Specialist
NY
There was a TSB for the 2010's. I had mine replaced at dealership. was doing the same thing, brake lights would stay on and once and a while hill descent control fault would flash. Bring this to your dealer.
Hill Decent Control Fault. SSM 21317
Oasis special service message number: 21317
message title: 2010 svt raptor - hill decent control fault and dtc c116a
applicable vehicles :
2010 truck : 00029 f-series ld
oasis message :
Some 2010 f-150 svt raptor vehicles may exhibit hill decent control fault with
abs dtc c116a. On vehicles built before 2/26/2010 only, inspect the high mounted
stop lamp for evidence of water intrusion. Refer to wsm section 417-01 for
replacement details part number al3z-13200-a. Torque screws to 1.5 nm / 13
lb-in. No water intrusion follow wsm section 206-09, pin point test i. Note: It
is normal for the brake pressure (brakpres) pid to occasionally spike high due
to test pulse sent to the pressure sensor by the abs module. In addition, brake
pressure signals as low as -225 psi without brake apply should also be
considered normal. .
Applicable symptom codes :
200000 electrical
206000 electrical warning indicators
300000 chassis
301000 chassis service brake system
Raptor2010
PA
oasis message :
200000 electrical
300000 chassis
Didn't know they had a tsp on it, thanks.
INI
Land, Sea, Air
mine is jacked up too
the LEDS only come on when you tap the brakes. they do not come on with the running lights. any thoughts. i have to drop it off at the dealer for 2 days. no thank you
Raptor2010
PA
They are only suppose to work when you hit the brakes. That's all the LED's are for. Your ok with yours.
Raptor Retrofit
HID Specialist
NY
no, the three led's in the 3rd brake light should be on when marker lights are on and they should brighten when brakes applied.
