Help! Multiple system failure and wont start
14raptorsvt
Elgin, AZ
Hello Raptor Fans!
My 2020 Screw Took a dump today and left me stranded. Multiple system warnings came up and the truck shut down and would not restart. Ran Forescan and this came up.
(OK) [15:55:34.112] Disconnected
(WARN) [15:55:45.699] Checking FTDI #1:D37PC05K...
(OK) [15:55:51.096] Connection to adapter has been established: FTDI #1:D37PC05K
(OK) [15:55:51.098] Adapter: vLinker FS v2.2.88 MIC3322 V2.0.88 (ELM327 v2.2)
(OK) [15:55:51.188] Connection to vehicle has been established
(OK) [15:55:51.272] Vehicle: Ford F-150 EcoBoost Gasoline Turbocharged Direct Injection 3.5L 2018 MY
(OK) [15:55:58.092] Found module: TCM - Transmission Control Module
(WARN) [15:55:59.203] DTCs in TCM: U0422:00-2C
(OK) [15:55:59.250] Found module: PCM - Powertrain Control Module
(WARN) [15:56:01.856] Module PCM has no DTC function
(OK) [15:56:04.290] Found module: APIM - Accessory Protocol Interface Module
(OK) [15:56:04.928] Found module: DCDC - DC to DC Converter Control Module
(WARN) [15:56:05.066] DTCs in DCDC: U0100:87-2B
(OK) [15:56:05.369] Found module: PAM - Parking Aid Module
(WARN) [15:56:05.664] DTCs in PAM: U0100:00-2B, U0557:00-2B
(OK) [15:56:06.333] Found module: BdyCM - Body Control Module
(WARN) [15:56:08.179] DTCs in BdyCM: U3006:16-08, U3007:16-08, B11DB:08-08, U0100:87-0A
(OK) [15:56:08.460] Found module: BECMB - Battery Energy Control Module B
(WARN) [15:56:08.608] DTCs in BECMB: U0100:87-0A
(OK) [15:56:10.309] Found module: SODR - Side Obstacle Detection Control Module - Right
(WARN) [15:56:10.479] DTCs in SODR: U0100:00-AB, U0401:86-28
(OK) [15:56:10.836] Found module: SODL - Side Obstacle Detection Control Module - Left
(WARN) [15:56:11.047] DTCs in SODL: U0100:00-AB, U0401:86-28
(OK) [15:56:12.090] Found module: IPMB - Image Processing Module B
(OK) [15:56:12.609] Found module: FCIM - Front Controls Interface Module
(WARN) [15:56:13.286] DTCs in FCIM: U0401:00-08, U0401:82-0A
(OK) [15:56:14.240] Found module: ATCM - All Terrain Control Module
(OK) [15:56:14.781] Found module: TRM - Trailer Module
(WARN) [15:56:15.015] DTCs in TRM: U0140:00-2F
(OK) [15:56:15.254] Found module: DSP - (Audio) Digital Signal Processing Module
(OK) [15:56:15.924] Found module: SCME - Front Seat Climate Control Module
(OK) [15:56:17.261] Found module: OCS - Occupant Classification System Module
(WARN) [15:56:17.445] DTCs in OCS: U0100:00-2B, U0401:00-28
(OK) [15:56:17.870] Found module: C-CM - Cruise-Control Module
(OK) [15:56:18.870] Found module: TCCM - Transfer Case Control Module
(WARN) [15:56:19.130] DTCs in TCCM: U0100:00-0A
(OK) [15:56:19.407] Found module: ABS - Antilock braking system
(WARN) [15:56:20.256] DTCs in ABS: C0037:14-28, C003A:14-28, C1A95:2F-28, C2007:13-28, C2008:13-28, U0100:00-AF, U0401:00-AF
(OK) [15:56:20.585] Found module: TrlrBM - Trailer Brake Control Module
(WARN) [15:56:20.789] DTCs in TrlrBM: U0100:00-0B
(OK) [15:56:21.894] Found module: TCU - Telematic Control Unit Module
(WARN) [15:56:22.206] DTCs in TCU: U0100:00-0A, U0253:00-08
(OK) [15:56:22.626] Found module: RTM - Radio Transceiver Module
(WARN) [15:56:22.952] DTCs in RTM: U0401:82-2F
(OK) [15:56:23.386] Found module: DSM - Driver's Seat Module
(OK) [15:56:24.027] Found module: PDM - Passengers Door Control Unit
(OK) [15:56:25.065] Found module: DDM - Drivers Door Module
(OK) [15:56:25.625] Found module: RCM - Restraint Control Module
(WARN) [15:56:26.568] DTCs in RCM: U0100:00-8B, B00A0:68-8B, B11D8:14-08, U0413:92-8B
(OK) [15:56:26.954] Found module: PSCM - Power Steering Control Module
(WARN) [15:56:27.514] DTCs in PSCM: U0100:00-0B, U0401:00-0B, U3003:16-08
(OK) [15:56:28.140] Found module: ACM - Audio Control Module
(WARN) [15:56:28.410] DTCs in ACM: U0100:00-0A
(OK) [15:56:28.670] Found module: SCCM - Steering Column Control Module
(OK) [15:56:29.114] Found module: IPC - Instrument Panel Control Module
(WARN) [15:56:29.593] DTCs in IPC: U0100:00-0A, U0401:82-0A, U0232:00-08, U0233:00-08, U0401:00-0A, U0401:81-08, U0415:00-08
(OK) [15:56:29.892] Found module: GWM - Gateway Module A
(OK) [15:56:30.295] Found module: HSWM - Heated Steering Wheel Module
(OK) [15:56:32.221] Found module: IPMA - Image Processing Module A
(WARN) [15:56:32.830] DTCs in IPMA: U0100:00-AF, U0401:86-28, U0418:86-28
(OK) [15:57:05.121] Disconnected
I have checked all the wiring connections and replaced the Fuel pump driver control module with no luck.
Any help would be much appreciated.
First things first: Pictures. Or it’s a prius
Welcome to FRF
Multi-system failure “out of the blue”... Battery and BMS reset would be my first guess.
any modifications?
any recent changes - say 90 days back?
are you the original owner?
you say 2020, why does FORSCAN say 2018?
14raptorsvt
Elgin, AZ
No Prius Here,
I am not the original owner. Purchased with 25K on the clock and now sitting at 65K
No mods or changes within the last year.
Battery replaced, BMS and all modules except the PCM can be reset with forscan.
It does have a stage I cobb tune. The tuner will not connect so I am unable to remove the tune.
I am not sure why forscan says 2018. I have 2 configuration profiles in forscan. The original and the current one loaded that says 2018. I have checked harnesses and connectors and can not find any damage.
The PCM has no DTC function which makes me think its fried!!
