M&R Behind the Grille 34" Light Bar Setup
Fred
Richmond, VA
I like it. Can the bar be placed below the FORD also?
On a side note; when did Sasquatch stop doing Jacklink commercials and start working for you guys?
That Mullet is awesome. Oh for the 80's. That is what I call a "lower bracket". No offense just kidding
The lights look great. Standing by to order!
MandR Automotive
MandR Automotive
Haha it mounts to the metal grill support brackets. We are going to provide a template where to make a small bolt hole on each side and it fits perfectly.
Aaron
Meme Corps Commandant
WA
Won't that be to long for that bracket?
Rigid measures the lens, so theirs is a 40" and M&R measures the body so it's a 44", but they're the same exact size. Just different ways of measuring.
Correct me if I'm wrong M&R...
MandR Automotive
MandR Automotive
It's the same measurements. As far as the below the FORD sign you can fit the 40" easy. The lense is 40", the bar itaelf is 41.5", and with two L brackets it's 44". We are yet to release mounting hardware but rigids should work.
In terms of the over the FORD sign, there is 32 inches between the grill support frame. By using our template to make proper aligning mounting holes, you can use the 34" bar without its L shaped legs (resulting in 31.5" bar installation)
