Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
How To: Install Deaver Springs on your Ford Raptor
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BOJANGLES" data-source="post: 6105" data-attributes="member: 21"><p>-Leaking some gear oil from my rear diff (where I mounted that *** Spider rock guard). Funny thing is ive had it installed for a few months and it didn't leak a drop... Now all the sudden my rear diff is needing that Tampax Heavy Flow. </p><p></p><p>-brakes are squealing again, dealer is replacing the pads with the Ford non-motorcraft ones.</p><p></p><p>-third brake light is letting in water/moisture.</p><p></p><p>-hill descent control fault light has gone on and off a couple of times. I once read on a thread that someone linked this problem to moisture getting into the 3rd brake light and rusting a component in it thus creating some kind of wiring glitch and tripping the fault light. I have no idea whether that's true or possible, but I found it interesting that I also discovered the two problems around the same time.</p><p></p><p>-passenger airbag fault light was on, now it's off but they're checking it out.</p><p></p><p>-gasket/seal of my windshield has a gap in it big enough to let moisture in at the lower passenger side corner.... looks like a factory mistake. They're replacing it and will hopefully keep my windshield intact in the process.</p><p></p><p></p><p></p><p>With that laundry list of problems and my gear concerns, I decided it was probably a good idea to let someone who has a Ford logo on their shirt and doesn't have a beer in their hand check it out.</p></blockquote><p></p>
[QUOTE="BOJANGLES, post: 6105, member: 21"] -Leaking some gear oil from my rear diff (where I mounted that *** Spider rock guard). Funny thing is ive had it installed for a few months and it didn't leak a drop... Now all the sudden my rear diff is needing that Tampax Heavy Flow. -brakes are squealing again, dealer is replacing the pads with the Ford non-motorcraft ones. -third brake light is letting in water/moisture. -hill descent control fault light has gone on and off a couple of times. I once read on a thread that someone linked this problem to moisture getting into the 3rd brake light and rusting a component in it thus creating some kind of wiring glitch and tripping the fault light. I have no idea whether that's true or possible, but I found it interesting that I also discovered the two problems around the same time. -passenger airbag fault light was on, now it's off but they're checking it out. -gasket/seal of my windshield has a gap in it big enough to let moisture in at the lower passenger side corner.... looks like a factory mistake. They're replacing it and will hopefully keep my windshield intact in the process. With that laundry list of problems and my gear concerns, I decided it was probably a good idea to let someone who has a Ford logo on their shirt and doesn't have a beer in their hand check it out. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Socks
khunter
RaptorFun
FJohnny
Sever18
HighwaySentinel
RCorsa
Frogger22
flyitaway
jonnyV
Rao in the 6
Rocks2Sand
MurderedOutSVT
jriggsaz
futurepr3
Reptar854
refine
ToadSmasher2K1
Jmbeebe0722
Bvt60
IIAWAH808
Romo
peeweeman250
Rekkr
RaptorAU
TheC-Don
new raptor
riv
Advcgh
Winchester30
kactux
ln13ln13
Brad12
Finlay150
chrishaugh17
cazt51
Johnny@Apollo-Optics
Tigmandick
93,631
56,935
ID_AZ
Forums
Accept
Learn more…
