Anyone get this code P0455
BenBB
Lots of different places
I got that code last year, in my case wasn't the filler but the CPV and I got one from amazon like @panda . $46 or so and instantly cured it, along with another symptom I had, that it felt like the engine would die right after filling with fuel (if the CPV fails the fuel vapors essentially flood the engine).
Dan096
Purge valve check,unplug valve,remove line from valve,start vehicle if you feel vacuum valve bad,needs replaced.will set code because of being unplugged. Valve is problem 99% of the time,install new valve and clear code
