HOW TO: 2019+ Live Valve Recalibration - FORScan
TexasAggie94
Harker Heights, TX
Disconnect the battery for a bit and start again?
I'll give that a shot; the error (Drive Control Malfunction) has never occurred in the three years I have owned my truck until I ran this calibration. That part is my biggest concern. I also had no noted failures after my suspension was upgraded back in July 21. I sure hope this works. Thank you.
2022 Ruth
Ohio
Great info.
ForScan is a great tool. Eventually I’d like to figure out how to disable live valve altogether.
B
blwn
Florida
Do you have a tune? Running the latest version of Forscan?
B
blwn
Florida
I'd suggest clearing all the codes and trying again. Make sure your battery is in good shape or hook up a charger while running Forscan
K223
Florida
True, the modules are very sensitive to weak voltage and will exhibit quirky behavior and still appear to be operating on the ok side.
TexasAggie94
Harker Heights, TX
Well, I disconnected the battery and reconnected. Hooked up laptop w/ powersupply and OBD. Calibration is still showing 199 on front left and zero for all others but I shot a note to FordTechOne about the error code and he is suggesting I flash the VDM Module with as built info to reset and hopefully it will remove the Drive Control Malfunction and the calibration discrepancy. Are you suggesting to have a battery charger hooked up to the truck battery as well?
K223
Florida
Depending on the batteries state of charge and how long this will take, it’s probably best to do. I would let it charge some even before starting.
TexasAggie94
Harker Heights, TX
BLUF: Calibrated and error free. I appreciate everyone's help today and would like to share all that I learned on this 8+ hour journey today. The five-minute job that went sideways.
So, after quickly completing the height calibration I was unable to zero out my front left ride height value. In fact it was reading 199 which I now believe is a maximum value. Immediately following a "successful" calibration process in FORSCAN not only did I have the erroneous value but now I had the Drive Mode Malfunction being generated in the VDM. After several attempts at reloading the VDM with "as built", running ride height calibration, resetting the VDM module, and disconnecting the battery I was left with the same error (which locks you out of all driving and steering modes) as well as the 199 in the front left. So, I decided to look at the ride height sensors themselves and found that the front left ride height sensor linkage that connects to the upper control arm had popped off the ball joint. So, when I did the initial ride height calibration it read a value that gave such a large number that it triggered the VDM to create the Drive Mode Functionality to fail. Once I found the issue, popped the linkage back on between the sensor and the UCA, I was able to successfully zero the right height then force an as built load into the VDM module and the Drive Mode error was gone. Thank you Baby Jesus! Moral of the story, never give up! Link.jpg
K223
Florida
Cool glad you fixed it. I was going to suggest checking the harness connection to them, but figured you may have already. How that popped off is pretty interesting. But it can happen. How many times do the small and obvious things burn you? Yup never give up.
