GEN 2 Baja Designs S1 Flush Mount Install
surfnsocal
San Clemente, CA
I installed a pair of flush mounts S1's in the work/scene configuration. Installation was really easy. Took a lot of time positioning them.
One thing that is weird is BD's website says you can install these with a 1" hole saw. However in the directions, it reads 2.5" (accurate).
I decided to wire them to an AUX switch and not tap in to the reverse lights. There are some instances when I don't want them to come on (late night departures in residential neighborhoods, draws attention, etc.).
I'm really happy with how they turned out. The work/scene lens is REALLY bright (I can only imagine the Wide/Corner or Spot). Enough to help with backing up, hooking my trailer up, or running in the desert.
full
full
full
full
Normal Reverse Lights
full
BD S1 Work/Scene
full
JohnyPython
Canada
That’s awesome!! I was planning this out for the spring. I’m totally with you in wiring to the up fitter switches. Thanks for posting this.
I decided to wire them to an AUX switch and not tap in to the reverse lights. There are some instances when I don't want them to come on (late night departures in residence neighborhoods, draw attention, etc.).
full
full
full
full
full
BD S1 Work/Scene
full
I’ve got older model squadron sports out back, and initially I had up fitter only, but I found I kept leaving them on when I’d back into a parking spot, then take off again later.
Nice clean install.
WY
this looks really nice, I've been wanting to do some reverse lights, but I don't really want them hanging below the bumper. I like this option.
On my old truck i had a 3 position switch so i could have them on with reverse lights, off, or on independent from reverse lights. That set up was ideal. I wonder if that could be done using two upfitter switches?
4x4TruckLEDs.com
If you want to do the flush mount S1s there are only 3 parts you need
S1 Flush Mount (2 of them): http://www.4x4truckleds.com/baja-designs-s1-led-flush-mount-wide-cornering/
Our Harness: http://www.4x4truckleds.com/crystal...ness-for-2017-ford-raptor-s1-s2-reverse-kits/
Upfitter Connection (to tap into the rear): http://www.4x4truckleds.com/baja-designs-ford-upfitter-wiring-harness-squadron-pro-sport-s2/
